regenerate thumbnail for posts
i have gone through all setting which are mentioned to generate thumbnail for posts & home. Even with same setting i can’t able to generate thumbnails please do help to fix this issue. i m trying to generate thumbnail for rajapushpa.in/blog & rest of the blog posts
Hello !
Please make sure that you have cleared your cache. As you can see here the images do work: https://www.screencast.com/t/kZ31hJZrU .
