I tried to add related article after 3rd paragraph by following the topic https://forum.tagdiv.com/topic/add-related-on-2-paragraph/
It is displaying properly in desktop but it is not aligning properly in mobile version. Here is the screenshot of mobile version. https://imgur.com/a/O4pxJHy
Hello @Satheeshraj !
Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to make it look better. There are some settings for meta info that will help you set the block: https://forum.tagdiv.com/flex-block-settings-guide/
This I have already tried. in Mobile view port if I reduced the title letter count then it is happening in desktop version too. Can u please specify what exact change I can do in mobile view port to make it proper.
Hello @satheeshraj !
No, it shouldn’t. Please click on the mobile viewport and then change the font size.
First of all, you need to have space for that text; if not, you can modify the size of the image, and you can also limit the excerpt or title there.
The easiest method is to upload a block that is already responsive from the Cloud Library:
1. Edit the page (the one you’d like to have the block) with the TagDiv Composer.
2. Click here: https://prnt.sc/SelGe0HUURYB
3. You can find only blocks and sections: https://prnt.sc/SLKHPjRB3Cia
4. Choose the one from there and click on the green button import.
