Related article widget above comment section
Since I use the theme my mobile page views dropt with 1% – I think this is because of the comment section on mobile. Before we showed our related or finest posts of the day before the comment section. As we all know users ar lazy as … so we need to make it easy for them. I don’t want to use the mobile plugin – this doesn’t works for me – ad placements…
I tried to use a plugin – Add Widget After Content – works fine on desktop but nothing happens on mobile.
Issue is that I don’t want it on desktop but only on mobile…
I hope you can understand what I mean and help me out with this.
There is a related articles/more from author section displayed after the post content
– https://forum.tagdiv.com/related-articles/
This is displayed when using the mobile theme plugin as well.
If you do not want to use the mobile plugin, simply deactivate it. It is not required to be active. Then the same content from desktop will be displayed on mobile.
The mobile theme plugin probably does not recognize the content added by the other plugin you are using, so it will not be displayed.
