Related Articles by Tags not working reliably
Hi, I was looking if I could find a similar issue but was not successful.
I have set the “Related articles” setting to “by tags”. However, not all articles (sometimes none) are shown that have the same tag.
Example: This article https://www.thedigitalpictureframe.com/check-the-exif-data-of-your-images-to-prepare-your-photo-frame-for-smart-playlists/ has (amongst others) the tags “Pi3D” and “Python”. There is 1 other article that contains the tag “Pi3D” and 5 that contain the tag “Python” (Example: https://www.thedigitalpictureframe.com/tag/pi3d/ and https://www.thedigitalpictureframe.com/tag/python/). Yet only one article with “Pi3D” is being shown.
How can I make sure that all Related Articles that have at least one tag in common are shown (up to my specified limit of Related Posts shown of course)? Thanks!
I made a test for this problem that you are facing, but for me this is working normally -> https://www.screencast.com/t/XaVI4FvJyGO -> https://www.screencast.com/t/AsrsFc7G
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
Thanks for making a test, Calin. I will check carefully what you are suggesting and then report back.
