related articles inside post
How to add related articles inside post I can’t find any block by newspaper.
Unfortunately, the block of ” related articles “no longer exists, but you can add a flex block and filter it => https://www.screencast.com/t/SEmxo13Fo2X if you have a Single Post Template from Cloud Library.
but if you have a standard post template , please make sure you have this option enable from Theme Panel -> Post Settings -> Related article => https://www.screencast.com/t/baIJDruAWKFt
Hope this helps you!
