related articles more from author wrong posts
Hello, our site posts have “Related Articles” and “More From Author” box enabled. I like this feature!
Unfortunately, both of these elements are displaying the same set of articles, under the “Related Articles” and “More From Author” tabs … even articles that are from different author.
Example here. You will see what I mean, by looking at bottom of that article, and toggle back and forth both tabs … same posts! 🙁
So apparently the array of posts being used to populate these boxes is somehow not filtering properly. Or the loop is messed up … or something! 🙂
Any ideas on where to look? Where do those elements get their array of posts? Maybe that offers a clue?
Please update your theme to the latest version of the theme 7.1.1 as there was an issue with these elements that was fixed: http://screencast.com/t/AC4cmR69Urb2
Thank you Bogdan, updating theme files fixed this issue, thanks!
