Related articles not showing and there's a white box next to menu in Mobile
Somehow there’s a white box next to menu, around the scroll area and cannot be removed while its in mobile mode. Also I turned on the related articles button but its not showing in articles.
In order to avoid misunderstandings, then please provide more information about what you need to change, like screenshots.
There simply is no related articles under all my articles
Hello @jeffreytszchung!
If you are referring about this setting: https://www.screencast.com/t/Z7Fba3cfJ ; then this will apply for default post templates and not for cloud/pro ones.
For the cloud/pro post templates, you should access the post, edit it with the tagdiv Composer and add, customize the element called “Flex Block” as in this video: https://www.screencast.com/t/iHnNCerv
