Hello, do you know of any plugin that gives to put ‘Related Posting’ inside posts, not in the end? I want some plugin with image.
The developers of the theme could put the option to choose where to appear related articles of the site, not just below the post, but in the middle …
Olá, vocês sabem de algum plugin que dá para colocar ‘Arquivos Relacionados’ dentro do posts, não no final? Quero algum plugin com imagem.
Os desenvolvedores do tema, poderia colocar a opção de escolher aonde aparecer os artigos relacionados do site, não apenas em baixo do post, mas no meio…
Check this plugin (but some features are paid) https://wordpress.org/plugins/intelly-related-posts/.
If you want to change the position of the related articles section for post pages, you need to edit the single post template and move the code which call this functionality like this -> https://www.screencast.com/t/IUu4OrV4RO
You should edit the post content function from the code -> https://www.screencast.com/t/cAsFw8CZw7j3 If you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
