Hello !
Those blocks are no longer available. Now you can add that through flex blocks with filtering options: https://www.screencast.com/t/f5CV38ffxe
Hello !
If you are using a post template from the cloud library you can change the last block and add a flex block which will allow you to make more changes to it. As you can see here you can have the relation using the filter tab: https://www.screencast.com/t/kEAnOPRbzG
Hello !
Sorry for misunderstanding !
You can set the relation of the related posts in here: https://i.imgur.com/N2UobM1.png
I hope this was more helpful !
