I have selected the custom “Single Post Template – Magazine PRO” template for the single post.
I don’t know how to add a Related Posts section at the end of the page.
It is possible to show related posts, but only if I select other post templates…
What can I do? thanks!
If you install the Magazine Pro single template, then there is a block-related article at the bottom of your post: https://prnt.sc/GyhCT3LWEfkb
What do you need to achieve there exactly?
Hello Bettina,
I need exactly a block like that, with related posts.
In the admin bar I see this:
https://app.screencast.com/OwyTqf6cqJg5f
I click on “Edit with TagDIV composer”, but I don’t see that block at the end of the post. What is its name? Is there a way to add it in the template? I don’t find anything similar to that block in the left “Add element” menu…
Thank you
Carlo
Hello Carlo!
This is the block: https://prnt.sc/tER8qxX9dDB1
Maybe you’ve deleted it by mistake, so please re-install the template from here: https://prnt.sc/tdNoZv_IlQGK -> https://prnt.sc/I1tUKz4q-dnr -> https://prnt.sc/Vzog0FaKoJCs -> https://prnt.sc/l7Zxf0LjAPrc
