I have accessed your website -> http://www.happytv.gr/ but it seems that you have enabled some screen protection tool and I cannot check it, sorry! Please make sure if you are using the latest version of the theme installed via FTP way, enabled the Mobile Theme, clear all the caches, purge CDN files and check the results. You can provide some useful screenshots with the problems and also, provide a specific URL where I can investigate this problem.
I look forward to helping you!
Please try to enable the thumbnails from the Theme panel from here -> https://www.screencast.com/t/HX3MefYsll
This issue seems to come from your Lazyloading. Try to disable this option from Theme panel from here -> https://www.screencast.com/t/6RDvQZKvTFd Clear all the caches, purge CDN files and check the results. Check here -> https://www.screencast.com/t/CrKlOaMPz
Thanks for oyur understanding!
Try to comment out the code from here -> https://www.screencast.com/t/dlhOLUKU4wlY Clear all the caches, purge CDN files and check the results. If you want to hide that section for the entire website, you can do it from here -> https://www.screencast.com/t/Gck2SKqPjaA
Hope this helps!
