I use the WordPress Related Posts plugin in my blog with the Newspaper theme. All my articles and also footer section are published with templates I downloaded from Cloud Library. The related posts section is published without problems on articles pages. However, it is also published once more at the bottom of the page under the Footer section. This is not a nice image and distorts the layout and standard. This problem does not occur on pages, it only occurs on article pages.
Site address: http://www.arthenos.com
What is the reason for this, how do I solve this problem?
Thanks in advance for your interest and help.
Regards.
I think that the plugin set the Related posts on all posts/pages that have a content shortcode.
For the moment you can fix this using a custom css like this one.
.single .td-footer-page .wp_rp_content{
display: none!important;
-> https://i.imgur.com/wMlJbCS.png
The code need to be set in theme panel> custom code> custom css.
Hope this will help you!
