Relationship between Theme Panel and DivTag Composer
I think I’m missing something fundamental. When I create my own header or use a premade one from the Cloud Templates, none of the values I set in the Theme Panel are being picked up. For example, if I set the color to red in “Theme Panel > Theme Colors > Header > Text Logo Color” and then add a Header Logo element in my header, the color of the logo text is not red. I realize I can set the color in the DivTag Composer, but I had assumed that was for overriding the site wide settings in Theme Panel. Another example is that in “Theme Panel > Header > Text Logo” I have set a value like “My Header”, but when I add a Header Logo element it doesn’t pick that value up. I have tried setting a bunch of different values in Theme Editor and only a few of them seem to make any difference. What is the point of Theme Panel if the elements in DivTag Composer can’t reference them. Are there variables I can use or something like that? Like in DivTag Composer put $TEXT_LOGO as the value? Or for colors put $THEME_ACCENT_COLOR?
Hello !
Please note that when importing a cloud library template that will become fully editable using the tagDiv Composer.
TagDiv Composer will work on Cloud library and Theme panel will work on default templates.
Why not make both? That is, if I import a cloud library template and set color to default, it picks up the color from theme panel. As it is now, if I import a template from cloud library, I have to sacrifice the ability to make site wide changes. This is sub-optimal.
Hello !
This is how our developers created this features based on other users suggestions. Also the future will be tagDiv Composer because it gives you endless posibilities in editing all the small details from your page.
Thank you for your understanding !
Hello !
At the moment the Support team is not 24/7 available. Please note that we answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2 So multiple replies to your topic will only make us to get harder to your topic.
HI Help me
Hello !
Also please do not spam all the topics on this forum !
