Remote Images won't work with Smart Lists
I’ve tried every combination of post layouts and smart list styles, along with disabling all plugins to be sure – smart lists do not work with the very same remote images that work fine in a normal post. Just something to work on.
  • This topic was modified 11 years by Bryson T.
To be clearer, remote images simply will not display in smart lists.
Also found that using Photon in Jetpack breaks the smart lists. http://prntscr.com/5wjb9f
Please provide more details that how you placed the image, some screenshots. Also a link would help.
Thank you for the message!
The image was default after a content import from my main blog to my development blog, where I’m customizing the theme. This is done on different domains (localhost is a PITA to set up things like Jetpack, which is needed). Selecting to download attachments during the import process does not actually download the attachments; usually just remotely links to them.
I’ve corrected the issue already so I can’t show you a screenshot. Thought I’d pass it along.
Glad you’ve managed to fix it. We will also investigate this and try to fix this in next theme versions.
Thanks for reporting this!
