Remove add body class
hi there i try to make some customization,
so i add custom “page-id” and custom “header-custom”.
now i try to remove class from “header-custom” and add some new classes.
i try to do that:
<script>$("body").removeClass("td-ad-background-link").addClass("demo");</script>
after <body> section but this dont work.
can you help me with this? thanks
The easiest way to add extra classes is to simply edit the theme file and add your class in the html. if the header is what you are after, then here is where you can find it: http://screencast.com/t/e9eesMck. Also if you want to customize a specific header style: http://screencast.com/t/vAkvG8txAQFT
You have access to the html directly so you can add classes to it as you want/
Ok but can I remove classes?
Or remove one and add one class in body =” class”?
My JavaScript code don’t work with your theme for some
Reason? Maybe I must put it somewhere else?
Thanks for help
You can add an extra class on the body like so: http://screencast.com/t/GWupJ57FdDi
I’m not sure what class you are trying to remove unfortunately so I;m not sure what solution I can provide based on just that.
Keanu remove “td-ad-background-link class, but I want remove this class and add new in specific page not in all site!
You can find the class being added here: http://screencast.com/t/gftUWu4TIXf
