Remove comment counter in post, but keep view counter
Hi there,
I would like to remove the comment counter in the post but keep the view counter as we have currently disallowed comments, please see below example.
https://imgur.com/a/LpD5nQg
Best
  • This topic was modified 5 years by diafne.
If I understood correctly, you want to remove the Single Post Comments Counter => https://www.screencast.com/t/WovjQmZf3
If you have Single Post Template, to remove you need to edit with tagDiv Composer, select the element and with a right-click, you can delete => https://www.screencast.com/t/6WnNGq6NFx or select the element with drag & drop place into the deleting red zone from the bottom right of the page.
If you have a standard post template, you need to go to Theme Panel -> Post Settings -> Post and Custom Post Types => https://www.screencast.com/t/TftzSAfTWtC and disable the option comment count (please make sure you have the tagDiv Standard Pack activate)
Hope this helps you!
Thank you very much for coming back to me – unfortunately, I cant see the “Post and Custom Post Types” part, is that because I do not have tagDiv Standard Pack activated? If so how do I activate it?
That can be done using tagDiv Composer. Open tagDiv Composer over your template as you can see here, simply right click – delete: https://www.screencast.com/t/6bCiojYviEhU
