There are options for removing this post data from the theme panel, but if you remove them from there, they will not appear in the modules and blocks. So the best thing to do in this case is to hide them with css. You will need to be more specific as to where you want them removed and where not to as the ‘three little boxes’ is not particularly specific. Please provide a link to your website so we can see your homepage and specify if you want the data removed from the article itself or on the modules and blocks on the homepage so i can provide the proper css code for it.
