Remove Shadow between header and content section?
I’m been searching and trying different things and nothing I do turns off the shadow between the header and the content. Where is this controlled?
Please edit header with tagDiv Composer, select the zone on the header menu, and in the General tab is the option Shadow, please set the value to 0 => https://www.screencast.com/t/XgYQNKEOSnCi
Hope this helps you!
Nothing I do get’s rid of the shadow on mobile.
https://imgur.com/a/vQurqPX
You need to do the same for mobile https://www.screencast.com/t/pMWkyvRpp
I tried that too but it is still showing up.
https://imgur.com/a/RjjYSAP
Set all values from Shadow to 0 an it should work well from desktop and mobile viewport.
Let me know the results!
I’ve done that and it still shows up.
https://imgur.com/a/AB380eq
Can I just use some custom css to turn it off everywhere possibly?
– admin url and credentials
Our team will take a look!
Was there ever a resolution to this? I am getting the same issue.
Hello @podcastmovement!
If you want, we can take a look in your case also. Please make a full backup, send an email at contact@tagdiv.com and provide wp-admin, more information about your issue, screenshots or videos, so we can investigate this issue. Also paste a link to this topic so we can easily identify you.
Hi Bettina,
I also have the same issue having followed all the instructions
https://golfquotes.co.uk/wp-content/uploads/2021/10/shadow.png
Is there a fix available, or do I also have to email you separately as above?
I’m using a cloud template header.
Many thanks
Neil
Hello Neil!
Please check if there is no shadow in the content zone also. If you verified everywhere, then please contact us via email with the admin credentials and we will let you know from where this shadow is displaying there.
Thanks Bettina,
Yes, I’d set the shadow to zero in the content area also and still it is there 🙁
I’ll email the admin credentials to you now.
Many thanks
Neil
