Remove Unique post filter from Block 9
How to remove the unique filter?
tried so far puting remove_filter(“td_wp_booster_module_constructor”, $this, $post); in the module8 file but no luck.
Please advice.
I’ve managed some workaround by duplicating: td_module.php into td_module2.php, and so on for td_block, td_data_source. Then i modified block9 to use the *2.php files where in data_source the unique filter is comment out.Worked like a charm
If you have any other suggestions, please post here.
