You can remove the home from the breadcrumb from this setting: https://www.screencast.com/t/DX5DCr1byH7
This also depends on the page title you type in for your page. If your page is named home it will show home->home
If your page is named page it will show heme->page
The page title is removed from a page by changing to a page template that does not show the page title: https://forum.tagdiv.com/page-templates-2/
You remove it by using visual composer. If visual composer is detected on a page then the title is removed.
You can use even a simple text box. Just make sure you press the add button and place the text box yourself as all the content existing on your page is already in an ad box. The theme needs to create an element from the list in order to remove the menu.
