Removing 'Previous Article' and 'Next Article'
I tried adding to the css
#paging,.entry-related{
display:none;
This did not work.
How can I remove that, I don’t see a setting. I tried searching the knowledge base but could not locate anything.
Reference post: http://kratomnewsnetwork.com/usa-local-and-state-kratom-news/is-kratom-legal-in-alaska/
If this is what you want to achieve https://www.screencast.com/t/Sv5NE68FGhhn please add this custom css in Theme panel>Custom code>Custom css
.post .td-post-next-prev{
display: none;
If you want to hide only de text with next/prev https://www.screencast.com/t/N6IyP7VlauZ
use this code:
.post .td-post-next-prev span{
display: none;
