Repeated Posts for Infinite Load pagination
I have an issue of infinite load pagination. i used Block 3 as my Sidebar widget, and Sort by Random Post, using Infinite Load pagination, http://www.screencast.com/t/5mYEi6EZLf and i found out there are a lot of repeated posts. http://www.screencast.com/t/tksSAUAGaD
Please advise whether this is a known bug.
This is the default behavior when you set you block this way. After the 10 post limit you set, the other posts will display random which includes the ones already shown. The filter does not detect which post is shown previously so these situations can occur. Unfortunately for the random sort order there is no solution for double posts. This is on our list of improvements and in a future update we hope we will be able to implement an option to make these random posts unique.
As an alternative you can sort your posts in a different way or use pagination so doubled posts will not be as obvious.
