replace add box per simple linkeable images
how can i replace the header Ad (adsense) on home page for a simple clickable image.
You can use this method to ad custom ads on your website: https://forum.tagdiv.com/using-other-ads/
For a simple clickable image, you can use html like for example:
<a href="#"><img src="insert image path here"/></a>
  • This reply was modified 10 years by Bogdan B..
