Hello Tag Div,
Your theme is perfect. One reason why I buy it is your perfect login form. It is cool but have one issue.
If you have standard users like Administrator you can login properly and everything is OK.
I have membership site and I have S2 members system plugin. If user have S2 member level membership and when try log by your login form. Login is jammed and you must hit F5. If page refresh. You are logged.
For better show this issue I made for you test site and test accounts. I will be happy if you can fix this issue in your future updates.
I made for you showcase for understanding issue
Go to my test page http://www.xczechstudios.com – it is clean instalation with newest theme version 6.7.2.
Login with – tagdiv1/tagdiv – User as author – fully functional
Login with – tagdivs2/tagdiv – User as S2 member member – login jam (you must hit F5 to proper login)
I test it on more sites and same issue is everywhere. I will be happy if you can solve this login form issue in your future update.
Thanks a lot
Jan Dudek
This topic was modified 10 years by
xczech.
Hello Jan,
I saw the issue and it’s as you described it, but unfortunately our login was designed to work only with the default user roles of wordpress: https://codex.wordpress.org/Roles_and_Capabilities
This is not an issue, but just the way the login was designed. Unfortunately since the plugin is not tested we are not certain how to ‘fix’ the login. Untested plugins do not represent theme issues. They are just untested plugins that change the default wordpress functionality that our theme cannot recognize or vice-versa.
The base login is located here:
http://screencast.com/t/1ZLus1hdCH – http://screencast.com/t/ABKMorw97L
These are the base files for the login widget of our theme. There are however other places the login is specified in different conditions like the comments login: http://screencast.com/t/iWzXfpsKgF
Hope this helps.
Alternatively, if you do not want tio hire a freelancer, maybe you can use a login plugin that already has the features you require. I cannot make any recommendations though.
