In the past I have uploaded some custom fonts to customize the theme via the Theme Panel -> Theme fonts, but now for optimize reasons I want to delete those fonts, I already deleted the fonts in the Panel:
https://imgur.com/5EWrGds
And deleted the fonts files in the Media Library, but now GTmetrix and Chrome Browser Console is showing bad requests:
https://imgur.com/lq6oJrd
https://imgur.com/qh19Qpd
Can you help me to reset the fonts settings to the default values please.
Hi Edbit, the problem is that you deleted the fonts but you do not change it on the elements you have at that time set, now the theme is searching for these fonts and can not load theme, that is way you get these errors, to fix it you must change the fonts on default or set it on google fonts.
Hi Calin,
No, I deleted the Custom font files first from the Newspaper Theme Panel the I deleted the files in the WordPress Media Library.
https://imgur.com/dUjZrYB
I have already activated the option “Use Google Fonts” and the theme is showing the font Robot correctly but in the Web Consoles the theme is still searching for the deleted files.
https://imgur.com/lX7Pc7T
https://imgur.com/jW40M3l
Can you just tell me a way to reset the fonts sections of the theme to the default options, please?
Hi Edbit,
Unfortunately there is no option to reset only the theme fonts, there is a general option in theme panel -> import/export section – https://forum.tagdiv.com/import-export-theme-settings/ but this will reset all the settings from theme panel. Also if this style was set using tagDiv Composer on some elements you need to change in the same way.
Please provide me a link to your website and I will try to help you to remove the style from the elements that are still check after that font.
Hi Calin,
Fortunately I don’t think I have used the Custom Fonts in the tagDiv Composer. The website link is:
https://www.talent-republic.tv/
Thank you
Hi Edbit, I just checked your website an now I do not longer found a place where to be try to load the font from your screenshot, maybe this was only in cache, to make sure about this, clear all cache from your website, host and the browser that you are using.
