Responsive Image Problem on Homepage Post
Greetings tagdiv team,
I’m experiencing issues with “Homepage post” block images when trying to resize the screen. It appears to be a responsive problem.
It appears that when I use wide photos I have problems, but with square images it works ok.
This is an example when I adjust the window explorer:
https://ibb.co/bG5PXk – this is normal
https://ibb.co/gC58sk – problem
https://ibb.co/fPdiQ5 – problem
I was wondering if you guys have an idea. Is it because of the photo resolution and size? If I crop it and make it square I don’t have any issues.
P.S. I tried with multiple browsers same problem.
Hello Cosmic,
It seems to be a strange issue. Your photo is stretched incorrectly. Please provide your website so I will be able to provide a more accurate response. After this, please remove all of your untested plugins, clear all the caches and check the results. Notice that behavior does not happen on the default theme, without any untested plugins. I have tested on my side and this block seems to work as expected, without any problems.
Hi Catalin,
Here’s an example for two different post using Homepage Post type:
https://revistacosmos.com/axis-mundi-si-geto-dacia/ – this photo is almost square (1600×1500) and it’s working.
https://revistacosmos.com/sirul-fibonacci-ascuns-in-data-nasterii/ – this photo is wide
(1700×1000) and shows a bad stretch.
The wider the photo the more it looks incorrectly.
I know is working good for the default theme. I use only legitimate plugins and I can’t disable them because they are vital. I was hoping you guys have an idea, otherwise I’ll have to make sure I’ll upload each time photos that aren’t wide.
Hello Cosmic,
Please notice that post template uses a full-width for this image in the post template and the image should have to be big enough to occupy the entire space. To be sure you get the desired results you should use images that are at least full HD.
