Responsive option issue in column section
There is issue regarding the responsiveness of the visual composer. I am trying to hide the column in mobile and smaller devices by marking the check box in column responsive option but the column still shows up.
  • This topic was modified 8 years by bishwa.
Hello bishwa,
Most likely, you have active both page builders. Disable the TD Composer, clear all the caches and check the results. The VC functionality should works as expected again.
