Responsive problem with WP Ninja Tables Pro
Hi there TagDiv team.
I use the wp ninja tables pro plugin (their dev investigated that there is a theme issue)
On mobile devices (and amp), after theme update, the tables don’t show up correctly, probably the theme overides the settings of the table (fixed image dimensions, hide columns on mobile etc).
Please note that I CAN NOT add the shortcode using html/text modules from tagdiv because they don’t save!
Link egamers.io/blockchain-games-list/ (from smartphones)
thank you
Hello !
We can find a fix for the saving problem. We need to take a look and see what happened there.
– admin url and credentials
Our team will take a look !
