Latest version of Newspaper installed.
I have an issue when using a Cloud template for the single post view on mobile devices. When using a Cloud template the content beneath the featured image isn’t centred correctly and appears to have padding added to the right side of the screen. The footer appears correctly.
If I remove the Cloud template the issue is resolved.
No cache on and I’ve removed plug inns to see if it’s a conflict but no success.
Any ideas ?
Please edit the Single Post Template with tagDiv Composer, select the viewport on phone, and after select the element Single Post Featured Image -> https://i.imgur.com/7vIddsf.png and check if the element is set margin or padding in the tab CSS.
Also, please check this topic https://forum.tagdiv.com/topic/mobile-template-spacing/
I managed to correct the error by adding 1px padding to the left side of the elements that don’t display in the centre but now it looks out in the Tag Div composer but looks ok on mobile. Visually on mobile it seems to have moved more than 1px.
Feels like a quick fix to something that isn’t behaving as it’s supposed too but thanks for the advice.
