Review box modification issue
I want to add a sentence to my review descriptions, which contains a link:
review description
But when I do this manually, that happens:
previous post?
The same sentence also appears in the previous post section.
I’d like to modify my td_review.php so that it adds that sentence (URL) to all of my review descriptions. But without showing it elsewehere, of course.
How can I do this?
I also tested this and seems that it is an issue when you add link in review description. I have added this on our list and it will be fixed soon as possible.
If you want to add link in the review file you can add it here: http://screencast.com/t/8fRwtIGYNvY
Result: http://screencast.com/t/wpZzghudl1q
Thanks for reporting!
