Review element not working with Gourmet pro single post templates
This is my first day using the newspaper theme , all I have done is install a demo and now I am here looking for support.
I tried to create a review post but seems like there is some bug happening. As soon as I try to create a review post with gourmet pro templates, the posts page started giving a fatal error and stopped responding.
After running some file checks, seems like the tagDiv cloud library plugin was shooting the error. just after deactivating the plugin, the posts started working and again activating it was creating the error.
Also, I tried uninstalling and reinstalling the Demo, just as I uninstalled the demo the review element started showing on the post and after installation again stopped showing.
Please help regarding this, as most of my posts are review posts and i am hoping to go with the Gourmet demo too.
Hi Komal,
The Gourmet pro demo use cloud templates, therefore it can be edited using tagDiv Composer -> https://i.imgur.com/VouHHH9.png and make sure that you have add the reviews -> https://i.imgur.com/Ox914M2.png -> https://i.imgur.com/Sm7pyya.png the results will be -> https://i.imgur.com/0OdQz0R.png
Hi Calin,
Yes, I have added the reviews, but it still does not show in the posts. As soon as I update the post after adding review content, it switches back to general.
No other plugins than the newspaper’s own library are installed or activated.
Are you suggesting that I need to edit the template using the composer, just converting the single post into a review won’t work?
Hello !
Yes, you will have to edit your post template and add the REVIEW element as you can see here: https://www.screencast.com/t/xPvM92W7RdS
