Review module questions
Hi there, two questions about the review module:
1. How to change the color of the stars in star ratings?
2. Would it be possible to display the review module above rather than below the post?
1. Please check this custom css in Theme Panel > Custom Css: http://screencast.com/t/fisaZY2tD
.td-review .td-review-final-star {
color: green;
Also if you want to change this on modules you can use this custom css – http://screencast.com/t/6cWnFuBWKaHN
.entry-review-stars {
color: green;
2. You have to edit the template file that you use – http://screencast.com/t/4Ws3SlEBS
Result bellow featured image on default post template – http://screencast.com/t/t8QbpPW59luWhttp://screencast.com/t/EuskmHrQ05mi
This worked like a charm – thanks!
