hi
whenever I have a post with a review score on it doesnt show either the date or author on the article display. I am using M1.
http://connecteddigitalworld.com
How can I correct this?
thanks
Andrew
Hello aedney,
Unfortunately, our theme does not have a simple option to display the author name and the date for the posts with the review. For achieving that it is necessary to do some additional customization in the code file. In order to achieve as you wish, you have to change the td_module_php file like this -> http://screencast.com/t/5kX80TRqkxY and if you want to get what you want, the snippet of the code in td_module.php for reviews will be like this -> http://screencast.com/t/YYkQNFl7 The snippet of the code that will be replaced over the old one is here -> http://pastebin.com/Vv6jYbfY
The result you should see here -> http://screencast.com/t/QdttmwgIS
Thank you for the message!
