Review Schema Problems..
Hallo,
I have problems with review.
Google does not recognize any review.
Item
type: http://schema.org/review
property:
name: Nokia Lumia 1520 – Phablet mit Windows 8.1
author: xxx xxx
datecreated: 2014-11-29T13:31:02+00:00
interactioncount: UserComments:0
maincontentofpage:
Item 1
Fehler: Page contains property "maincontentofpage" which is not part of the schema.
Please make sure you have the latest version 1.1. We have fixed that in the latest update.
Hallo Marius,
Of course, I have the new version 1.1. See the pic:
http://download.magpc.de/Unbenannt.JPG
Link to page where the error is happening likely useful here 🙂
Please make sure that you try this without any plugins active just to make sure that this isn’t caused by a plugin. If you still get this error please give us wp-access and send your login details at contact@tagdiv.com including a link to this topic or specify your issue in details.
