Review system composition in composer: how to
Hi, i just noticed that after switning from newsmag to newspaper my reviews lost the review system at the bottom of single posts.
By searching here i’ve been able to make it show by editing with composer, but i’m not able to style it as show on your DEMO which is how i used to have it before.
I’m referring to black space from single “post review overview” to the others elements (ref.1 on image linked)
and the difference in high from “review summary” and “review overall” (ref.2 on image linked)
Image with Ref.1 and Ref.2
Thanks for help in advance.
  • This topic was modified 4 years by reloaded.
Hello @reloaded!
In order to avoid misunderstandings, then please provide more information about the issue, screenshots(with the settings you applied) or a video and your website link.
Hi Bettina,
i’ll try to explain with screenshots.
So the original layout you show is this one: Newsmag Star review original layout
The one i was able to configure looks like this: MT star review layout
So you can clearly see in my layout there is some white blank space between star score and summary/overall score
AND
Summary’s bottom border line is not perfectly aligned with overall score’s border line. Ref1 and Ref2 of previous post
I can show you how it looks my review system in composer:
Star review system in composer
Summary in composer
Overall score in composer
What i was asking is to make it looks exactly as you demo page which is how it used to look before when i was using Newsmag theme.
Thanks. Hope it helped.
  • This reply was modified 4 years by reloaded.
Note: the second issue, the border line alignment, if it is a problem of “number of lines written in the summary” then ok, make as if problem is solved.
But if instead there is a way to make them look always perfectly aligned i would like to know how.
Hello @reloaded!
Please try to set up a margin zero to the elements like this: https://prnt.sc/GSbAqqO6JuY9
So, the orange space from bottom will disappear. Also, try to align the number of lines in summary with the element from the right side.
Hope that helps you!
1. Ok thanks, issue nr. 1 solved with your hint.
2. Concerning issue nr.2 i decided to leave it as default.
I found where to modify in composer (Summary box -> General Tab -> Box padding by adding a 3rd px dimension) in order to align the two boxes but i noticed that the behaviour changes depending on the kind of overall score (if it has 2 digits it appears in a way, if it has 3 digits with comma it appears in a total different way). So default is probably a better option.
I’m saying this in case maybe someone else is looking for this kind of solution.
