If you are using a single post template, you can use the tagDiv Composer to edit the template and relocate the review position to a different location – https://i.imgur.com/rkYfWhQ.png
Or if you want to review via block, then the only way will be to use custom css to change the place or create your module https://forum.tagdiv.com/meta-info-modules-blocks/
