Tried your review templates and template 1 and 3 generates these nice “Must Read” section but I noticed template no. 2 does not have one.
Template 1 is working fine http://prntscr.com/kikl4m also 3. Applied template 2 http://prntscr.com/kiklju, http://prntscr.com/kikm0e summary, and star images are okay but no “Must Read” section http://prntscr.com/kikmdv
Thank you
I don’t quite understand what you mean exactly. That “Must read” looks like a block, which would be in no relation to the reviews, except being in the same sidebar from what I can see.
If it displays “No posts” then I suggest that you check it’s filtering and sorting settings, it might have no posts to display due to incorrect settings.
