Newspaper is the perfect theme for my editorial website. We write reviews about movies, books, etc. The problem is that when I use the Review post setting, the schema generated in the page should be only “review” and NOT product. Books and movies are not products in my case, but articles with a critical review. I think you should fix this thing since the theme is made for newpapers and journalists should be able to vote for the thing they write about. Thanks!
Example: https://www.culturamente.it/libri/finche-il-caffe-e-caldo-recensione/
Hi Alessia Pizzi,
The review system was made like that because most of the time the review is about some products and not about the article. What can be do right now is to change the schema from the theme. This is on wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php -> https://i.imgur.com/pPFInSt.png and in wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php -> https://i.imgur.com/mYYSf80.png all that need to be done is to replace https://schema.org/Product with the schema.org that you need (I think it is https://schema.org/Article).
