Reviews in posts not showing
Hello. I’m trying to use the review functionality in one of my posts. I’ve filled out the info but it doesn’t seem to show when previewing. I’ve checked to make sure the “Reviews System” is enabled in the Post Settings of the Theme Panel. Is there something else I need to check? Does the review need to be added to the post as a short code?
Here are some screen shots
Thank you
  • This topic was modified 1 year by sidog. Reason: image url fix
It looks like I was using a custom post template that didn’t have the review components. You can mark this one as closed.
I’m glad that you found the issue.
Have a nice day!
