Revolution slider problem?
hi,
I’ve been doing alot of testing to increase pagespeed. By deactivating Revolution Slider I get 100/100 – 100/100 in PageSpeed Insights. When I activate it I instantly loose 20 points. Have you done anything on the demo to improve this?
Also, Seems snapmenu stopped working after i disabled/enabled it..
screenie
actually the menu isn’t working at all
Best tip on slider, is optimize the heck out of the images used.
Also be aware that the mobile ratings have all gone down as they are even penalizing for the “tap area” for things like breadcrumbs now … our business site just dropped many points due to the breadcrumbs being “too small” on an information page. Sheesh. This is what I’m working on now. The mobile stuff I think Google is going a little overboard on, and also “assuming” everybody is going to only view a website in vertical mode vs landscape and not rating it both ways. They also assume everybody has the smallest phone from 3 years ago, vs the larger phones everybody is getting now, or the higher resolution of retina, etc. If you’re suddenly “under 80” again — on mobile — it’s not just you. My shtml/ssi based site which was fine, is now not due to this kind of shenanigans.
(sorry, rant over …)
I’ve actually optimized every single in the theme. Even backend 😛
It’s only because the theme is so great I’m pushing for KBs. I know my site is more than good enough to run as is. But no one likes red flashes on validators 😉
This topic kinda got merged into my other one as both “problems” seems to be rev slider related.
https://forum.tagdiv.com/topic/eliminate-render-blocking-javascript-and-css-in-above-the-fold-content-2/
I’ve added on github to make the compatibility between tagDiv Speed Booster plugin and Revolution slider.
