(Rich Snippets) Problem Newspaper7 theme
Hello I have a problem related to (Rich Snippets) of Newspaper theme.
The Newspaper uses (Rich Snippets Breadcrumbs) for links and this is a problem for me. I do not need Rich Snippets for links as it totally changes the way the link is indexed in search engines.
Rich Snippets to Breadcrumbs link can be very ultil for some people but for others may be completely detrimental bearing could have an option to disable it. (Tip is for a next version).
I disabled other theme but the Newspaper files is very complex, looking at the file (td_wp_booster_functions) did not find anything related to Rich Snippets to Breadcrumbs link.
How can I remove (Rich Snippets Breadcrumbs) for links?
Hello fabiosoft,
You can read about breadcrumbs here – https://developers.google.com/structured-data/breadcrumbs and if you want to change it from the code, you will have to edit this folder -> http://screencast.com/t/tYPYscgVEr9f
If you need more additional customization and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because we cannot provide customization services at the moment, sorry!
Hope this helps!
Thanks for your message!
