Has something changed with the ‘Right Click Element Menu’? I can no longer access it by right clicking on the word ‘element’. This means I can no longer save my elements to use elsewehere on the site. very frustrating. My website is tvblackbox.com.au
Me too – Yoast deactivated solves the problem.
I took up Yoast because, I think, Google Ads recommend it.
There’s an incompatibility then between NP and one of the most required plugins on the web?
Thankyou for the advice Langolo and Mark, I can confirm disabling the Yoast SEO plugin resolved this issue for me as well. Would be good if tagDiv and Yoast teams can find a solution to this bug as it is a very popular and useful plugin. Cheers
Indeed there seems to be some problems and the js script use for the right click, when yoast seo plugin is enable some code from this plugin is interfering with our theme code -> https://i.imgur.com/4gtgXlM.png, one of our developers is checking this problem and we’ll try to provide a fix as soon as possible.
