Right-click menu doesn't work / unable to delete rows and columns.
I am using Newspaper latest version. Recently I tried to build my Home page on Default Pro template. I decided to delete some rows and elements in order to build my own layout. But unfortunately, I was unable to do so as it’s impossible to delete rows and columns. I could manage to do that neither with the Delete button from the keyboard nor from Tagdiv composer itself. Also, the right-click menu also doesn’t work.
Could you please help me to solve the issue.
Thank you beforehand!
You will have to first start looking for a plugin conflict.
Please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
Usually, the problem is from the plugin Gutenberg, if you have this plugin please disable and check to see if the problem persists.
Thank you very much for your quick response and help. I was using Gutenberg plugin and after deactivating it everything started to work.
Thank you very much!
I’m glad that the problem has been solved.
If you have other questions, let us know!
Have a nice day!
