Is it just me, but the right click menu does not seem to show on the Tag Div Composer. I have used it before to save some elements but now its not showing. Please clarify.
Hi Sophia_FACES, this option is still in tagDiv Composer, but most probably when you are using more then tagDiv plugins, this option can be block/removed. Please make a test let only theme plugins clear all cache and check to see if the right click is working in tagDiv Composer.
Let me know the results!
