I’m having problems inserting an image in the background of a row, when I mark the “no repeat” option, the image becomes very small, when I mark the “contain” or “cover” option it gets a low, distorted resolution. The problem is not the image because it is in high resolution (3840×2400). Also, when I add a color overlay over the image that is in the background of the row, the text inside the column elements are covered also, they are blurry.
I’m sending some Print Screens.
https://ibb.co/ku4zsn
https://ibb.co/kTGqyS
https://ibb.co/gVDQXn
THX!
Hello, I was able to find the solution to my problem in the forum (https://forum.tagdiv.com/topic/image-background-issues/).
Thx!
