Hi team, The RTL sub-menu is not aligned correctly
Is there a way to fix it?
In my link – please look at the main menue on the right with the letters חי פה
https://dev2.haipo.co.il/section/people-of-haifa
You ca also look at this image with me explanation:
https://dev2.haipo.co.il/wp-content/uploads/2024/02/sub-menue-flies-right.jpg
Hello @haipo!
You can fix it with some CSS or import a RTL header from RTL demos.
We have some RTL demos that were created by hand for this purpose using custom code: https://prnt.sc/ccPYeDT6mvKv Unfortunately, there is not a RTL feature in our theme.
So, you can correct any other demo in the same way.
Hi Bettina
Thanks for sharing your comment
The header is the RTL recommended by you: “Default RTL PRO”
But still it doesn’t work well
BTW, I purchased TAGDIV only because the RTL suppurt was announced as part of the solution.
So I really need some assistance to make the RTL stable.
Thanks,
Yaron
Hi Yaron,
I just try to check the prided link but for me is providing a 404 – https://i.imgur.com/9sscGzI.jpg like the page is no longer find or is not published.
Can you please provide some more details about the problem with them menu align problem? This will help use to understand what needs to be done to achieve what you need.
Sorry
I made some changes is my DEV2 system
Please check this url and try the dropdown menu on the right end
https://dev2.haipo.co.il/item/485841
It flies out of the site borders.
I expect it to align to the main menu node
Thanks,
Yaron
This reply was modified 2 years by
haipo.
Hi Yaron,
I think that now I understand what you mean, you are referring that the drop menu should be aligned like this – https://i.imgur.com/GwuJn8s.png right? If so then it can be done using the tagDiv Composer, edit the homepage and select the header main menu element and in general tab scroll to the sub menu options, there set first level left position – https://i.imgur.com/zfBhERN.jpg the number set there can be positive and negative to move the submenu to the left and right.
I thin that in your case it is possible that the number set to be around to -150.
I hope this will help you!
