HI Sir,
The problems on RTL or even on normal WordPress EN ,
My Site is on RTL (Arabic) , so
That when default CUSTOM SIDEBAR + POSITION on left postion .
Shows like
http://prntscr.com/3cvbge
or
On mobile views shows like :
That all fine and perfect , but the problem is when i change the options to Right sidebar :
http://prntscr.com/3cvd6q
or
My site show normally on Desktop :
but the problem in the mobile view :
http://prntscr.com/3cvfy0
or
so please i need to change sidebar postion to left and the post shows first then the sidebar sows second like it shows on the right position, so i’m waiting for your help ,
I Thank you , for your wonderful theme , ^_^ .
hi,
http://screencast.com/t/n0D20EyP
like here : http://screencast.com/t/HQ27X2PUiY
Thanks for you message.
Radu A.
thank you for reply,
i did what you told me :
then the sidebar goes down
http://prntscr.com/3czsoz
i need the change not for categories only but also for single posts
so please help me ^_^
hi,
sorry for misunderstanding, what I have written was not wrong but was not a copy and paste solution.
1) download this package : https://github.com/serbanghita/Mobile-Detect
2) copy the file : http://screencast.com/t/VpXwx0Oh7 here : http://screencast.com/t/ZWuXFw3g0
3) add this code in the function.php file
$detect = new Mobile_Detect;
$deviceType = ($detect->isMobile() ? ($detect->isTablet() ? 'tablet' : 'phone') : 'computer');
like here : http://screencast.com/t/8KSWWhcmhNT
4) modify the code in the category.php file
<?php if($deviceType == 'computer') {?>
<div class="span4 column_container">
<?php get_sidebar(); ?>
</div>
<?php }?>
and
<?php if($deviceType == 'phone') {?>
</div>
<?php }?>
like here: http://screencast.com/t/bGwnf90qhi
Radu A.
hi,
i did all the steps but :
leaded to :
please help < ^_^
Sorry Radu A , it did not work for me ,
but after that i’m searching for solution on Google i found to :
1) put Mobile_Detect.php file on the …
/wp-content/themes/Newspaper/
include 'Mobile_Detect.php';
then no problem on functions.php or error .
its after that work fine >
so because you are the best how can tell me , is it right or wrong ?
I thank you very much for your perfect help and i’m sorry for annoying ^_^
IHA
i need to
modify the code in the single.php file to make the same on single post,
where do i put/add this on single.php file ?
</div>
<?php }?>
and
</div>
<?php }?>
please teach me that on single.php thank you RaduA ^_^
IHA
hi,
well look for the get_sidebar() because this is what you are replacing.
iha, you see that we do offer support, but you are not a programmer, and you really don’t know what you are doing, please hire a programmer to modify the theme, it will save you (and us) of a lot of wasted time.
Radu A.
Ok RaduA , I Know what i did , so for others , the code in single.php
like
http://prntscr.com/3etgkb
so all it solved thank you RaduA , and sorry of wasted your Time .
the issue is closed here ,
Thank You ^_^
I did exactly as you wrote and… nothing… :/
the browser cannot load the website
Why you don’t fix it in the new releases? I want to use the left sidebar also, and it’s not normal if I want to read an article that I have to go down all over the sidebar because is the first in the code… doesn’t make sense
Sorry for all the trouble and for the inconvenience unfortunately as this hasn’t been changed within latest updates.
We have this on our attention and try to find a better implementation within newspaper 5 theme version.
You can try the solution Radu suggested until then.
Thanks for the message and for understating!
I did all the steps and it doesn’t work!
And you said that the next update will not support rtl
So how will you fix it if my website is on rtl??
You can make a small update to fix this big problem
Yes, you are right the rtl support will be removed in next version, however this issue doesn’t concerns just rtl users and the option to set the sidebar on the left will not be removed.
Unfortunately we can’t make an update for this but I’ll let you know when we have a fox for this.
Sorry for the inconvenience!
OMG ??????? rtl support will be removed in next version ????????
You Can’t Remove Features from your theme after 9000 bought it !!! , that’s not allowed in themeforest.net to remove this feature or Other Main Feature //
You told customers that this theme is RTL Support , You should keep the promise to the all Users So why SHAHIFA 5 still support RTL ????
