Apr 23, 2023 at 9:35 pm
Dear Support,
I started Running the CSS Analyzer from Google Chrome browser
and after one hour progress bar is on Step 31 of 83.
Desktip not Scrolled – running…
Please view a pic:
Can you help my about this issue.
URL: https://nook.rs
Thank you in advance
BR.
Apr 24, 2023 at 3:10 pm
Dear Anamaria,
thank you for you response.
Options Remove Generate CSS is disabled.
I can’t to click on that.
Apr 26, 2023 at 8:11 am
Did you run the analyzer until it finished? If appears like this https://i.imgur.com/3oKFnNs.png then it means you don’t have css generated
Apr 27, 2023 at 12:22 pm
Dear Anmaria,
Design is ok! but this option is not active.
I do not have any errors in logs…
