Safari problems with push notification and javascript code
Hello , we are using GoRoost service push notifications in Firefox , Chrome works perfectly but Safari did not launch the invitation those of goroost told me that this is a problem Javascript web page , you know how I solve or area code is located .
My website is http://www.superchannel22.com
Check your site with F12/Chrome to see various errors related to https, etc.
JQMIGRATE: Migrate is installed, version 1.4.1
superchannel22.com/:1667 Uncaught SyntaxError: Unexpected token <
superchannel22.com/:1 Uncaught (in promise) DOMException: Only secure origins are allowed (see: https://goo.gl/Y0ZkNV).
7u4l2m9pnliai9tvfryh1xs3sgdm1raa:76 Roost Error: Domain must use HTTPS to use Roost for Chrome.
7u4l2m9pnliai9tvfryh1xs3sgdm1raa:80 Roost: No supported implementation, cannot prompt.
util.js:207 Google Maps API warning: NoApiKeys https://developers.google.com/maps/documentation/javascript/error-messages#no-api-keys
util.js:207 Google Maps API warning: SensorNotRequired https://developers.google.com/maps/documentation/javascript/error-messages#sensor-not-required
js?v=3.exp&libraries=weather&sensor=false:34 Google Maps API error: MissingKeyMapError https://developers.google.com/maps/documentation/javascript/error-messages#missing-key-map-error_.ib @ js?v=3.exp&libraries=weather&sensor=false:34(anonymous function) @ common.js:51(anonymous function) @ common.js:194c @ common.js:45(anonymous function) @ AuthenticationService.Authenticate?1shttp%3A%2F%2Fsuperchannel22.com%2F&callback=_xdc_._spgzt8&toke…:1
@alanmtzh
we didn’t tested this service wit Newspaper theme and we can’t provide an accurate answer in this regard, sorry. Make sure that you followed their documentation when you setup the service and also check if there are no conflicts with some plugins that you have active.
