I have made two (de/en) pages for my site using the block 8 as an overview block with the composer. But it displays different on each language. You can see it here:
This happens on the bottom block. What’s wrong there? Thanks in advance!
Hello techmod,
Unfortunately, I do not know what kind of plugin you are using for this, sorry! You should try the Polylang or WPML because all of these seems to work as expected with the theme. The theme does not have any other option for this, sorry!
Hello techmod,
Please notice that kind of plugin has been tested for both of our themes and should work as expected, without any problems. First of all, check our documentation here -> https://forum.tagdiv.com/using-theme-translations-together-wmpl/ Also, you should try using the Polylang or Q Translate X.
Hope this helps!
Hello techmod,
I have inspected your website and I saw that your language switch button seems to work as expected and when the English language is active, all the site is in English and so let of forth. Sorry, if is not what you mean, please be more specific with your problem, provide some useful screenshots which what exactly you want to change, for a better understanding and also, so I will be able to provide a more accurate response. Please keep in mind that we do not plan to promote any plugin as you said above. The WPML plugin has been tested with our theme and should work as expected, sorry!
